Will the EEC cause the trans to jump out of gear. Or it that my trans is gonna. I have a new trans in my shop. But I was trying to wait until I got my high performance engine first. But if it is the trans I am going to change it now. But if it is the computer I was planning to get one from Super Coupe.
MLPS and low fluid can cause it to act like that. Any more specifics?
Discussion Starter · #4 ·
well it is fine from 1-2 but when I am driving it might jump out of overdrive and the only way it will get back in gear is to get off the gas and once the speed drop tp about 30 miles per hour it will get back in gear. The fluid is fine. And everything else works fine it is just this problem. I can be going 90 mph and it jumps out of gear. But it only does it every now and then.
Bad MLPS (Safety Neutral Switch at AutoZone).
