I just finished replacing the head gaskets because I was burning coolent. The white smoke on a hot day. The job started in early july. I just finished today and started the engine. Runs great, no smoke. Then when I tried to back it out of the dive way, the trans would not engage in any gear. The car was on jack stands in the front only, for four days. I has the shudder, trans cooler, mercon V. I am checking to see if I may have missed a connector, but I didnt take any trans connectors off. Please help!
Sheepish
Check the MLPS, but you should be able to get manual 2nd without anything hooked up, did you leak out any tranny fluid while the engine was out?
No leaks, but I will check the sensor in a few Min. Thanks.
