Hello all,
While changing my transmission fluid I discovered the main mount for the transmission is shot. However, there are also two bushings on the left and right end of the crossmember. I have been unable to find any part numbers or info on these bushings. The only place I've seen them was at SCP:
Anybody know if there is a universal bushing that would replace these? Energy suspension makes several that look similar to the above picture, but I'm not quite sure they will fit.
Thanks!
Discussion Starter #2
I'm wondering, maybe the crossmember is sold with the bushings as one item. Guess I'll just measure the old one and look up one that matches.
What’s wrong with buying the ones from SCP?
They're just a bit too expensive for me right now. Don't get me wrong, I'm not ragging on SCP or anything, but I'm pretty sure the bushing is an energy suspension one, which is significantly cheaper.
