Just curious as to wich fluid would be better for my 95 bird.....
Mercon® V ATF
or.......
MaxLife DEX/MERC ATF
IF you go Mercon V in a 95 (and it is a good idea) be sure you do a complete fluid change. drain the transmission AND the Torque Converter. Its not a good idea to be mixing fluid types, or at least that's what I've been told.
I planned on changing all off the fluid including changing the torque converter
I have never been a fan of royal purple fluids. I believe in maintenance not fluid designed to last forever. I used motorcraft MerconV in mine. If I wanted to go to a synthetic fluid I would probably go with amsoil because they do make a fluid specifically for the merconV.
Alan
