I have the transmission mod done, with all new springs and accumulators, and the drilled seperator plate. When I first got it, I noticed that on wide open 1-2 manual shifts I would squeek the tires. But under half throttle shifts, it seems to be squeeking the drivebelt. Is this right or am I crazy here?
Also, after a few hard shifts, the drivebelt smells like burned rubber. The drivebelt is a basically new goodyear gatorback, and it is installed correctly.
So, am i squeeking the belt, or am i nuts?
Justin
Ohio TCCoA
Ok, wo why causes it to do this and what are possible ways to fix it? I have the same done to my tranny and have the same prob. I alos did notice it with factory tranny.
later,
jay
Justin...
I have the same effect when I'm at part throttle on the 1-2 shift and also on the 2-3 shift with other people in the car. It's definitely the belt slipping. I thought I was the only one with this symptom when I mentioned it to A-Train back in october. It doesn't really bother me, so I don't call it a problem. It's just nice to know that it's not uncommon.
Jim
