ok, i have a small problem..when the 4R shifts into OD at part and full throttle. occasionally the trans will shudder into OD. Also, when shifting out of OD, say into 2..i know, 4-2 downsifts are bad, i dont do it manually..the trans also, shudders briefly into 2.
Final quirck, when goosing the throttle off idle or like a 5mph creep, i get a clunk sound/feel from where the transmission hump is..im guessing crappy mount..am i right?
whatch y'all think?
joseph
Sounds like the TC shudder to me... and mounts going will sometimes give a clunk, while sitting they vibrate the car a bit too. I think you're on the right track.
Tom
i need to change the fluid out....its been there for a while..maybe fresh fluid will help..it has Mercon V already..you said vibration..the car gets a wierd vibration starting at 60 worse at 80, then smooth at 100(dont ask). The tires and rims have been balanced with the Hunter super cool GSP 9700..im starting to think it has got to be the mount..looks like a have a new project.
joseph
