1 - 10 of 10 Posts
· Registered
i just destroyed the tranny. i expected it to happen at some point. i need the replacement to hold 475lb-ft and 525hp. dirty dogg? i guess in need some help getting the right piece the first time. i only want to spend $4000.00 - $5000.00 dollars. no more. thanks
· Registered
i dont know if alan would have time to build one right now since he is setting up his shop and starting a gp on converters right now (which would be a good idea to get in on). if he cant do it then get ahold of darrin.
· Registered
Discussion Starter · #3 ·
i need alan's
handle or phone number. thanks.
· Registered
Discussion Starter · #5 ·
cooler line cut. i will still send you my dyno stuff. i'm quite sure it will fail soon. at least after the holidays it won't interfere with things.
· Registered
Discussion Starter · #6 ·
darrin i need you e-mail so i can send you the dyno sheets for the converter. i also need your help getting the tranny to act right for me. i need the clutches to not lock at WOT. i want the converter torque multi for all gears at WOT. how do i do it. with a resistor terminated 2 pole switch? i will do this some time when the weather warms. hopefully before the tranny quits. it is slipping more. i have to baby it. it is my daily driver. i can't stand to drive any of my other cars. they just kill me with no torque.
-bill
· Registered
Discussion Starter · #10 ·
i sent the dyno to you darrin.
1 - 10 of 10 Posts
