which ones do i did to look at? i have a t-5 or a t-4 out of a mustang that i need to put in my 88 turbo coupe and i need help to do it. thats why i need to know which threads.
thanks
thanks
tuurbocoupe is a fox body....its not any different than a trans swap in a fox body.
fox body is a direct bolt in. Just go get everything off a 5-speed mustang. Only thing that will be different is the driveshaft, but I'm pretty sure you can just swap the T5 yoke onto your AOD driveshaft and it will work. Also the flywheel for the 2.3 is probably different than on the 5.0, so pick up a clutch and flywheel for a 5-speed turbo coupe.
SuperNewbie
