1 - 10 of 10 Posts
I got my 94 cougar 4.6L on the road. The check engine light is on. So I took it to work and used the Auto X-ray to scan the codes. I hooked it up to the ODBII looking connector inside under the passenger side dash. I used all 3 different color plugs with the scanner. Every time I got vehicle not responding! So is there something I'm doing wrong, or is there a different plug because its a 94? Isn't 94 obdI? I will add that the air bag light was on so I pulled the bulb yes it beeps at me. Could this be why the engine light is on? The car runs great, idles nice and smooth.
Yes the key was on.
Faster than Porkchop
check the fuse for the obdII
I was reading in my Chilton's book that the 94 is a EEC-IV not EEC-V like 95 up cars. They don't show you where the connector is. If you look at the pic in the book under the EEC-V is shows a pic of the 94 dash and say 1994 4.6L T-bird/Coug and points to the DLC under the passenger side dash. So what do I need to do. Going to look for the ODBII fuse. Found it in the fuse box diagram in the book. I just went and checked the ODBII fuse and it is good. Now what? Please help
So I wonder if I should tell the Auto Xray that mine is a 96 so it thinks its OBDII? Gonna try this later today.
Okay I scanned it today. I told the auto xray that it is a 96 and it scanned it right up. It said something about the Mass air meter. I cleared it out to see if it comes back on. Maybe it just need to be cleaned.
1 - 10 of 10 Posts
