Getting a Few different methods and clues to finding keyless entry code on my 95 . I read about its stamped on the back of black control box cover , which I removed and found multiple stamped codes .
I tried the " illuminated entry code" its 5 digits with one alphabet in between No luck .
Unless you have to actually press each digit carefully separated kind hard when one number seems to be part of a 2 number button.
So maybe your supposed to really pay attention to which exact numbers your pressing. I did this from a locked position and still no luck I haven't tried changing the combination order on the stamped code . But the 9/0 locks the doors
I even tried the keyless entry stamping code 5 digits with one alphabet.Neither work and the module looks old and original.
The small sticker on the trunk hinge that was supposed to have the code is long gone and no access to obd2 scanner currently any ideas on this .
If i was to get a obd2 scanner where is the code searchable within the scan tool?
