1 - 2 of 2 Posts
How would you make sure a relay works? I'm interested in AC cutout relay located in relay control panel along with PCM and fuel pump relays. Please help.
Thanks in advance,
Fernando
First thing you need is the pinout...
Apply voltage to the coil - a 12v flashlight battery is usually sufficient. And check the armature points for continuity. Repeat for multiple arms.
1 - 2 of 2 Posts
