The 5.0 "big bore" kit was relatively common in the past. Not as much lately, from what I've seen (here, anyway). This engine doesn't need more stroke, lol.
Getting a 4.6 to make power isn't necessarily hard, it's just not achievable using "bolt ons" like other designs that leave a lot of power on the table through such means.
As Brandon mentioned there is the 5.0 big bore kit but it’s very expensive and involved since the block needs to be resleeved, it creates more power potential since the larger bore unshrouds the valves but for the price tag you’re still only gaining .4 liters, enough to break the 300rwhp barrier many run into with 4.6 builds, but not by that much. Modulars have too narrow of bore spacing to get a really meaningful bore larger than 3.7”
Reserving cylinders gets really expensive, so the big bore kits are a high expense for what you get.
A stroker crank gets more cubes as well, but these engines have close piston skirt tolerances.
Making big power in these engines beyond the typical seems to require a power adder no matter what.
Don’t like strokers on these unless they’ve got a big bore in addition and/or positive displacement boost, for NA power the rod ratio is way too high and the valves are shrouded enough as is, that’s why 5.4 2Vs are such dogs
There wasn't anything earth shattering.
Matt's car is about as good as it gets, without radical cams, which are expensive for 4V engines, or power adders.
With the remainder of the TruBendz pipe kit installed, it is somewhat quieter and a little less raspy. It does continue to have an overwhelming drone which I hate.
I think I booted it on the xpipe instead of the crossover muffler, the pipe has no reservoir, no place for a pressure differential to cancel the drone, whereas the central muffler does. The central muffler also gives an odd number of PD spots, naturally defeating the drone harmonics. The even number of PDs I have only exacerbated it. I hope a pair of mufflers cures it. It's pretty bad.
A pair of rear mufflers should solve the drone.
I just installed the 2.5 inch trubendz kit with x pipe. I don't have any drone with stock cats and 2 rear mufflers. Mufflers are Borla xs series. Which I'm thrilled with btw.
Mine came out great. Very small modifications like adding cats and shortening one pipe for better clearances. My guy at the exhaust shop said it was a very nice kit to work with.
