5w30 Guzzler
did they make a trunk keyhole that was visible from being behind the car (about the same level as the blue oval, but in the middle) on EVERY 94 LX? the reason i ask is, when i bought my car used, the owner said the previous owner had taken the trunk lock out so no one could get into the trunk and steal his system. all i could see was that on the underside of the trunk (where it curves under) right above the license plate, there is a slit that if you sprayed water in it, it would get directly into the trunk (car wash has done it a little). just wanted to know if the guy had the lock shaved.
thanks
rob
5w30 Guzzler
thanks greenie
sorry i just got done watching the frank grimes episode of the simpsons.
rob
