I am looking to add a prop to my trunk following the instuctions listed in the forums. The info I need is how long is the prop overall? I work at a truck cap manufacting place and we have these gas shocks laying around all over the place for much less then 20 bucks...most of them only cost me around 5 bucks. I was just wondering if someone has a measurement on the total open length. Thanks~
I purcahsed my lift struts from Dan Newman, using the part number in the write up that I did.
That part number must be superceded, because I just went and checked the ones I have. This appears to be a newer part number;
F5ZB 63406A10 BA
They have the name STABILUS on them, and are located in Gastonia, NC 28052
The fully extended length is 19 1/8", measuring from center of ball socket to center of ball socket.
The rod moves inward a maximum of 7 3/4"
Hope this helps.
Thank you much...my gas props are from Suspa..we have all different poundage on them just the overall length was all I needed. Thanks again
