A chip is $325 plus shipping for a single program for a mild NA application.
http://www.blueovalchips.com/index.php?action=item&id=2&prevaction=category&previd=1&prevstart=0 If you want to make a change in the programming then it has to be sent back. If you are wanting more than one program then there's additional cost for each additional program.
The XCal 2 goes for $400 plus shipping with a single program for mild NA application.
http://www.blueovalchips.com/index.php?action=item&id=6&prevaction=category&previd=2&prevstart=0 With the XCal 2 you can make minor adjustments with the end user adjustability, On Device Adjustments (ODA).
http://www.blueovalchips.com/index.php?action=paramadjust So with this device you can make minor changes to the program or programs we provide in the device. If you need a new program it can be emailed to you. Then you just download the file into the device and then reprogram your vehicle. This device also data logs all engine and transmission function with the included software. It will read and clear CELs on any Ford vehicle OBD II Ford vehicle.
Each program is built to the customer's requests and or per our discussion of the vehicle's needs. Then once the program files are built we burn them into a chip or program them into the handheld tuners. This is why we call them custom programs. These are not ready made programs that most chip manufactures like Superchips, Jet, Hypertech or Diablo use that one program fits all. We've spent many hours on the dyno, at the track and then on the street over the past 8 years testing our programs to get the results we want. Our performance programs can entail up to and more than one hundred changes to the factory programming depending on the year, type and modifications to the vehicle. These changes not only include engine parameters but also transmission and torque converter for automatic vehicles. Removal of speed limiter, increased shift rpm, shift firmness and torque converter lockups (auto) are standard changes in all our programming unless otherwise notified. You can expect better throttle responds, drivability, some increase in mileage besides additional performance.
