1 - 20 of 37 Posts
Had a few problems with my turbo car at the Shootout this year. Biggest problem was it wouldn't make over 11 pounds of boost on the dyno and not much more on the track. Found out afterwards the main problem was with the fuel (straight 117 octane w/meth injection). I checked pretty much the entire turbo system over looking for the problem and never really found a smoking gun...just a bunch of little things. Fixed what I could and took it to a professional race shop to do the stuff that required fabrication.
Picked the car up from Dan Saitz's shop (Hyperformance) this afternoon and the differince is amazing. Turbo spools up much much faster and feels like it's making more power now at 12.5 pounds of boost than it did before at 15 pounds. Just rolling into the throttle blows the tires off in 1st, 2nd or 3rd. I'm gonna need to put the ET street radials back on it just so I can get a steady reading on the boost gauge.
Dan replaced the leaky Turbosmart 50mm wastegate with new JGS 50mm stainless wastegate, switched the .96 AR exhaust housing to a .81 AR, and went from a 3" mild steel downpipe to a 3.5" diameter stainless and fixed a few minor hotside leaks. While he had it on the lift I had him reseal the transmission pan, change filter and put some fresh JD hydraulic fluid in. Now I just need to install/rewire the new DCC Mrk8 fan and I'm ready to try racing or the dyno again.
Here's a few pictures before putting the turbo blanket back on.
David
who fabbed your manifold's? anybody local? any pics of them off the car?
with the smaller a/r does the car tend to run out of breath up top or have you been able to stay in it long enough to tell? i know these cold temps and street tires don't help much with traction..
I have always heard good things about hyperformance but never used them.. i've dealt with htp once in the past and they did good work...
The alternator looks really close to the piping, how hot does the exhaust side get right there?
The turbo system was built back in 2005 by a company called ForcedFab in Dayton OH. They did a pretty good job on the hotside part of the system, but did a horrible job on the coldside and final assembly of the system. See this thread for more info and pictures. Since it was originally built I've changed/upgraded several portions of the hotside to larger diameter stainless and now the only thing that remains as originally built on the hotside are the headers.
http://forums.tccoa.com/showthread.php?t=68687
Yes...I expected to give up about 50 rwhp on the peak power because of using the smaller exhaust housing. Don't really think that is going to be an issue because the car/driver can't really handle the amount of power it is capable of making. Even with the smaller housing it should still make at least 750 rwhp.
When considering that 99.9% of the time I'm driving it on the street with around 550 rwhp ( plenty to scare the crap out of me), I think the quicker spooling turbo and resulting increase in bottom end power more than makes up for any top end losses. Until I get up around 650 rwhp, I don't expect to see any reduction in power from the smaller housing. Keeping the .96 AR housing just in case I want to switch back to it one day.
Yesterday afternoon when I drove the car home, temps were unseasonalby warm at around 66 degrees, so I'm sure it would be much harder to get traction on a cold day like today with temps in the 30s.
Hyperformance does some top notch work and the guy who owns the place (Dan Saitz) is one of the few people I trust to work on my SCs. He's not cheap but he does excellent work. Here's a link to their website.
http://www.hyperformanceracing.com/
David
Yes it does look close, but fortunately I've never had a heat related alternator failure. With the turbo blanket on it doesn't really get as hot as it looks like it would.
I've looked at relocating the alternator but haven't really got serious about it because it doesn't seem to be an issue. The bigger issue is throwing the belt when racing the car. I can do all the dyno pulls I want or tear azz around on the street without ever having a problem, but nearly everytime I take it down the 1/4 mile I throw a belt on one out of every four or five passes.
Still experimenting with various belt lengths and pulley arrangments to find something I can rely on.
David
does the car still have power steering and A/C?
if so, removing those will help from throwing belts.....seems like a shorter belt would be the ticket....but thats saying if you want to get rid of those things.
Still has power steering and the turbo system will accept the AC compressor, but shortly after installing the turbo I ditched the AC and used used a revised belt routing. Smog pump was deleted before the turbo was installed.
Yes....getting the alternator moved over to the driver's side, where the AC compressor was located, would be the best solution because the belt would be much shorter.
David
Thanks guys. Sometimes this car seems like the never ending repair job....and other times (like now) it's hard to wipe the grin off my face. I'll let you know how it does on the dyno.
David
thats very nice david i never knew you were making that much power at the wheels.
I've scheduled the first post katrina meet in new orleans for february 21st. We'll have alot of supercoupes there and some exotic mn12s as well. I'm going to bring 2 of my supercoupes and my 351 5spd and my friend scott is going to bring his 89 cougar with an svo 351 and f1 procharger that made 1,032hp on the dyno. Should be a very memorable meet and is set for the weekend prior to mardi gras if you want to stick around and get drunk and see some boobies :) anywho, everyone is invited and we'd love for you to come. Estimated about 20 supercoupes as of thus far. Can't vouch for the n/a crowd yet because those figures are still up in the air but it should be a nice turn out none the less.
if interested give me a call and we'll talk
five oh four six oh six oh five three two
Man, I just gotta make it up there for a ride in the beast. :D
Discussion Starter #14
Is this a meet where you race the cars or more of a car show ?
David
Discussion Starter #15
I'll let you know the next time we have a TBU meet at my house. Now that WFC/WSC isn't happening anymore, we need to find something else to do in May.
David
been there done that!! need to upgrade!!!! i wanna drive it now!!!
David
chicago in july!!!
tell your friend scott to join up, post some pics and info about the 89....
Discussion Starter #18
chicago in july!!!
Keith,
It's a lot more refined and much faster than when you last rode in it. I'll let you drive it next time your in the area or at the next meet we both attend. If it doesn't scare you, then the beers are on me :D
David
Keith,
David
ill be sure to bring a spare pair of shorts.
Discussion Starter #20
Found out why the .96 AR housing wouldn't spool the turbo worth a damn.
Chalk another one up to those jackasses at Forced Fab who built this turbo system. Apparently this piece of pipe has been in the exhaust housing since it was built back in the fall of 2005. It also explains why the turbo spools so much faster and why it feels like it's making much more power at less boost since switching to the .81 AR housing.
I'll try driving it a while with the .81 housing, but I'll probably be putting the .96 housing back on before spring.
David
1 - 20 of 37 Posts
