OK, I have two thunderbirds... a 1988 TC which is beautiful but has a bad engine. I also have a destroyed 1990 3.8L V6.
I either need the engine from the 3.8 in the TC or the tranny from the TC in the 1990. This is out of necessity as I need a working car...which is easier??
Things to consider: The 1988 TC is a stickshift, the 1990 is an autotragic.
the 1988 TC is (aside from engine) perfect.
the 1990 has been wrecked...three times...at least.
Ideas???!?!?!
The transmission from the TC will not bolt up to your 3.8.
you woudl need a auto form form a 2.3l car, a 87-93 4cyl musdtang a4ld wil work just need to wire itn eh soliniod for cluctch lock up . you can also get a t-5 stick outta any 4cyl mustang also, same tranny, there woudl not be any swapping between the tow use completly differnt bellhousign bolt patterns
