i just upgraded to a t3/t4 turbo. does anyone know where i can find the right oil drain hose for the turbo?
thanks
steve
Is that the stock one on a Turbo Coupe?
Chris
where can i find one already made up? ive have it rigged together right now using half of the old one and the flange of my other car.
thanks
What kind of ends do you need? Is it pipe thread on both ends? If so what size? I know on alot of the import turbo stuff I have to use an 1/8th NPT to a #3 AN then build a #3hose between the turbo to the block. Then use another adapter at the block.
