1 - 20 of 39 Posts
Gents,
I have been doing a little research on turboing my bird and I would like a little input from those that have in some part completed the project. I think the hardest part I am having is getting the exhaust to the turbos. Here is my plan so please, point out the flaws in my thinking. I am thinking of getting the manifolds that are sold with one of the many Mustang turbo kits. From there, run a pipe from each to the small turbos, one located where the stock air box is and the other where the battery sits. The piping to the intercooler would run between the the engine block and the fan assembly. The piping exiting the intercooler would run from under the front bumper into the MAF and Intake assembly...like a normal CAI set-up. The spent exhaust gases would be piped out some how... I am working on that one. This is my plan. It is am idea and is not copyrighted or patented. I want to go fast and I want everyone else to go fast to. I am willing to share ideas. That is what it is all about. So, those with turbos in mind, let me know if what I have proposed will work. Later
House
Therein lies the problem. The Mustang has an extra couple of inches on each side of the motor compared to our cars. We get better suspension but give up space. The McPherson struts on the Stangs don't need as much real estate as the SLA suspension we have. So our shock towers are more substantial than their strut towers. Even with a tubular K-Member (which is NOT street proven yet) you're going to be UBER tight under there.
This is precisely why I did what I did on my car. I mounted the turbo remotely. I'm getting about a 110hp gain to the wheels on a 100% stock car. And that's without custom tuning at all.
Did you go with you own design or was it an STS kit. I looked at their kit and was impresed with it but I do have issues with it, with water pick-up and all but I did like the thought of it. And with that set-up, would it be feasible to get the lower portion of the trunk where the spare sits removed to better support that system if there are ground clearance issues.
And on performance, what is the lag like and how does it feel when the boost comes on?
There is no STS kit. I got raw mandrel U-bends and cut and welded the whole thing together. STS will not be making a kit for our cars. They're too busy with their existing projects. But I have exclusive license to produce the kits. So once I'm sure that any and all bugs are worked out, I'll look into getting the piping made up and kits available. The nice thing is that it'll work on the V8 and V6 cars equally well.
As for water intake issues, the heat in the turbo plus the speed of the compressor wheel will basically vaporize any splashed water. Now of course if you submerge it, you'd have problems, but what kind of fool drives through that kind of keep water anyway?
I'm looking at slightly changing the position of the turbo so that I can put a 90 degree elbow off the back of the turbo pointing straight up. That will put the air intake further out of harm's way. I only need about 1/2" to 3/4" to do that.
The only other ground clearance issue is with the wastegate, but I'm going to find a different place for that or at least a slightly different mounting angle that will afford more clearance.
As for lag, there is some, but that's mostly because of the stock converter. The cure for turbo lag in an automatic equipped car is more stall. But as it is boost starts coming on around 2600. By 3600 I'm into the wastegate pretty heavy, so there's more room to grow with it.
Boom.
Did you get on the rollers again, SW? Last numbers I saw were something like 211 horsepower or something like that...
The dyno numbers were crap, but the 1/4 times were showing around a 100 - 120 RWHP improvement.
Back when I was planning out a rear-mount turbo, I thought about water pickup pretty seriously, I didn't feel like chancing a hydro-locked engine. What I had thought about doing was basically cutting a hole in the side of the car, glassing a scoop over it, running pipe up from underneath to that hold and putting the filter there. It'd look odd, but oh well.
Full Metal
my only issue with the rear mount turbo would be losing my duals, my idea would be a twin turbo setup, the v6's have a little more room in the engine bay, doing twins would facilitate a dual exhaust setup,
it would be a mess of pipe routing but it can be done, hopefully i'll be able to do this by late next year, gotta get a second car while i'm working the bugs out of the bird's future twin turbo system, i'm pretty sure it isn't going to go together in a weekend, that would be my only problem, got to have a running work car so i can still go to work and still be able to boldly go where no mn12 enthusiast has gone before, well, with a 4.2L, anyways, lol
so Sir Will, did you have any driveability problems with your bird running turbo without a tune?
The car has a tune, it just hasn't been tuned. :D For right now I'm running a "base" blower SCT tune for my mods.
I have the SCT Pro Racer package so I can tweak to my heart's content. I also have a wideband O2 sensor/gauge so that I can keep a constant eye on the A/F ratio. Right now though, I don't have any datalogging software that wants to work, so I can't really dial it in completely. It's going pig rich above about 40% throttle, so there are some things that I need to adjust for. I just have to get datalogging capability and time to really work out all the issues. I'm sure I can lean it out a bit and add some spark in too. I just have to find out what the EEC is seeing before I start monkeying around with the 1's and 0's.
I still picked up over 100hp at the wheels. I'm not gonna argue with that. It can only get better from here. :D
Full Metal
:thumbsup: sweet! i'll prolly have to do something similar just to get mine running, nothing like melting a piston or something to ruin your day, lol.....:D
Refrigerator Raider Hater
I think twin turbos is asking alot. I think a single turbo (like a 62 series) would do nicely. Twins are vastly over rated, and they are less efficient. the reason they are used is because those little imports have no low end torque NA, so they need them to spool quickly. That's not the case for mn12s, we've got the cubes we need.
I've worked some numbers, and I would conservatively estimate 350bhp is quite doable on an otherwise stock NPI engine at just 6psi and 5500rpms. Open it upto 12psi and we are talking 450bhp still at just 5500rpms.
Full Metal
yeah, but it sounds cooler saying "yeah man, i got a twin turbo 4.2L V6 that i built myself" rather than saying "yeah, i got a turbo" lol.....:tongue:, not to mention the ability to keep my duals.....:D
Just saying you have a turbo powered Bird will be enough...then show them after they finish falling out laughing. Watch those smile get even larger when they hear a V8 thump and a turbo spool up.
Sir Will,
any thought of running an extended intake from the front. Air travels pretty quickly, and once you are rolling it will be fed into the turbo. My concern like others is the water pickup and things like that. And I remember you saying your setup is not and STS adaptation, did you just locate the parts and go to work? Also...how do you keep the turbo oiled? I read how STS does it and it seems like the way to go. And finally, what size and type of Turbo are you running? I am going to check around, and again look into the possiblilty of building a mounting rack where part of the trunk is to raise the level of the turbo, for clearance issues.
Big Will
Sir William congrats on the urbo setup. I have long pondered one myself and got it worked out, in my mind anyway. How is the "fun factor" of driving a V8 turbo in a MN12? Please tell me its as much fun as I think it is.
Blackbird: hres an old thread about htis topic-- http://forums.tccoa.com/showthread.php?s=&threadid=8145&perpage=30&highlight=turbocharger&pagenumber=3
Actually most sport compacts or rice burners run with single turbos. Although the 300ZX, Supra had twins, one of the forst mods done is to switch to a single large turbo. They do this because it makes more power and since they dont have the volume airflow like a V8 does they need to consolidate the flow into one turbo to make big power. A car liek ours woudl do great with twins like Tb/04 Garret or something laong those lines. I did the math for the airflow calculations and using two of these puts our car right into the middle of the compressor map for the majority of the power band. Also, right when our stock engine runs out of steam, the turbos stop producing as efficently so we don't lose any of the turbos benefits until we would lose the engine power anyways. And a bit of advice I think getting a hold of two dsm intercoolers ( side mount ) would work well as well. I mapped out and planned a twin setup for mine, the only question was if I could fit a 2-2.5 inch charge pipe through the engine bay . If so I can do it. Just need funds and a place to tear the car down. I think I could do it for about 3K. Probably closer to four htough.
This is an old post of mine, maybe it helps, I dont know:
--"I thought of doing a junkyard/ebay build. It would be a lot of fabrication though. But it all dpeends on time and how much money you want to spend. For about 600$ yo ucan get two Garret TB/04 or something similar turbos. You need two wastegates and can run with one blow off valve. Since we have a return style setup an fmu would probably be a good idea as well. The tricky part is running the necassary pipe and intercoolers.
My idea was to hack the exhaust off at the header flanges and build from their. Put the turbos where the catalytic converters are. Fabricate using molds/carbon fiber for air intakes and filter system. of course htis would have been under the car, making it less than ideal in the rain. It looks like you can just squeeze some 2-2.5" pipe around the bottom of the block to get the compressed air from the turbos forward. Go on ebay or two a junkyard and get two DSM intercooler, they were side mount and are real compact, makign them convenient as hell. You can get 2 into the bumper mounted horixzonatally. Not the best for intercooleng, but still good enough. Then route air over to the stock intake port where the air silencer is and up to the throttle body.
Sounds hairbrained as hell but it would work. We mocked up some stuff and it looked like it would work. You woudl have to do it all yourself because with that much fabrication, it would be insane to pay someone to do it. I've built a turbo header for a buddy of mine from scratch, its not terribly hard but takes time, took me and another guy a day to do it. get you some stainless and aluminized pipe and go for it.
Running two smaller garrets is great because once you do the math and look at compressor maps it keeps the airflow right in the turbos sweet spot. At idle the car is right at the start of the high effency range and moves out of it at 5000-5500 rpm, which is where our motors fall off anyway. To run a single turbo would not work as well since you would have to put up some money for a bigger one to move the air efficiently. Turbos are great because they allow you alot more flexibility and full control of your power output, but they are a pain, especially with an engine bay like ours. For you I would recomend a Vortec or procharger, both can be had for under 4K. Bolt it on over a weekend and your rolling. A turbo would take no less than 4-6 months to do I think. And cost about the same, maybe a little less f yo uwent real cheap.
That's awesome!!!!! :thumbsup:
You know everyone on TCCoA will have a turboed Thunderbird/Cougar now....
except the ones like me who have no money! :D
Gj SW!
It is QUITE awesome. I've had several people yelling my way asking what the noise was. Those who recognize it just give major thumbs up. It's pretty darned cool.
No real reason to run from the front. The system is NOT an STS system because they don't make one for our cars, but it is all sourced from STS. I have their turbo, oiling system, etc. But instead of a pre-built kit, I got lots of mandrel U-Bends and did it all myself. They will not be producing a kit for us, but I am planning to.
SW, when are you going to get us a video at the track or in the garage?
Discussion Starter #20
Saving money now. Will be a while but this is easier and has a higher cool factor than a supercharger. It is always nicer to do something that isn't seen everyday.
1 - 20 of 39 Posts
