My 1997 ordinary basic bird has a broken part on the turn signal lever. The knob that turns for the wipers is detached and wobbly. I can use the turn signal and I can spritz my windshield. DO you think I can attach it back on or does the lever need replacing?
I'm not sure I understand this post; You have a Broken Part, and you're asking if you should replace it?
:surprise:
Replace it, search for Multi-Function Switch and how to replace it and you'll be good to go.
Welcome! :)
:surprise:
I believe the OP is asking if he can fix his broken part or if the fix is to have the broken part replaced.
