Just a few days ago i noticed that my turn signals dont work, they started to work on occasion now they just dont work at all, does anyone know what da deal?
Thanx
PimpTipp
THERE MAY BE A CERTAIN WAY YOU CAN WIGGLE YOUR MULTIFUNCTION AND IT MAY WORK AT SOME TIMES. THESE MULTIFUNCTION SWITCHS VERY COMMONLY GO OUT AND NEED REPLACEMENT. YOUR WIPERS AND EMERGENCY FLASHERS MAY NOT WORK PROPERLY EITHER. ITS SIMPLE TO REPLACE. JUST REMOVE 2-3 SCREWS AND STEERING ADJUST HANDLE TO REMOVE COWL AROUND STEERING. THEN A T25 TORX WILL BE HOLDING THE SWITCH IN. BE CAREFUL NOT TO BREAK THE CONNECTORS!
mines doing the same thing at the moment, the blinkers will flash fast as hell and the the indicator on the dash won't blink... if you hold the turn signal lever just before it clicks over they work fine tho, which kind of pisses me off. rather have it not work at all than do something like that. turn signals, pfff who da hell needs em...
