1 - 20 of 44 Posts
I know using twin turbo's by having two turbo's of the same size is less efficient than using a single larger turbo. I've also heard using two turbos, one of a larger size and a smaller size has potential to increase performance. I know this is the prefered setup to create astronomical boost levels in diesel applications. Does anyone have information on using two turbo's of a dissimilar size on a gas engine? Could it offer an advantage over a single turbo... potentially with the smaller turbo coming to boost faster and the larger turbo providing more boost at higher rpms?
Cougar Pilot
"the smaller turbo coming to boost faster and the larger turbo providing more boost at higher rpms"
That's the advantage right there, if of course they're sized properly.
SanDiegoLXBird said:
A single will make a crapload more power, the twins are typically more streetable for the reason BlackCat mentioned, less lag.
A single large turbo will make more HP... But isn't this kind of like the debate between a screw type supercharger and a centrifugal? Yeah, the centrifugal might have more HP in the upper RPM range but the screw type will be faster, especially on the street.
Do supra's have two equal sized turbos?
How would the pipe routing look on something like that?
Cougar Pilot
I wouldn't know for sure, all of the trucks & heavy equipment I've driven only had a single turbo.
Do they run the exhaust through the small, then into the big one?
I would assume it to be the opposite... but either way wouldn't the smaller turbo be a restriction at higher RPM's that way? Could they somehow run them parallel or bypass one?
Sweet T
If twins are quicker, why is it that Outlaw Street and several other Drag Racing classes are dominated by big singles? Riddle me this.
If twins are quicker, why is it that Outlaw Street and several other Drag Racing classes are ted by big singles? Riddle me this.
Oh, I don't disagree... but they are purpose built cars rarely driven on the road. I'm just wondering if a twin setup would offer more for your daily driver by delivering more lower end power. And using two unequal size turbos could give you the best of both worlds.
Answer this, why do you think high performance diesels use twins (ie: pulling tractors)... they build more than 100lbs of boost by using two unequal size turbos in a series.
Class rules for one thing. Twin turbo's are generally considered to be dual power adders. Most of the time only a single power-adder is allowed or you go into a higher class.
Complexity for another. If a single turbo will get the job done and turbo response time is not an issue, then the single is the superior choice. Once you add the requirement of fast response to big power that's when twins begin to look good.
Chapter Director Coordinator
just use a larger single.. to reduce lag time.. add nitrous injection to spool the turbo up quicker at low rpms while racing... i know a few people who do that with much success..
Probably would make more sense to using nitrous and a single large turbo... but I would be interested in seeing how they set up a sequential twin turbo...
yeah, a hole shot would spool the turbo faster, as well as cooling the air charge, and adding more hp.
a twin turbo setup in series has the smaller turbo closest to the exhaust, then leads to the larger turbo. When the smaller one spools up sooner, it throws faster exhaust at the larger turbo, spooling that one up as well. But the smaller turbo can be a restriction, as the exhaust impeller is smaller than the larger turbo's.
Drag turbo setups are way different than street setups would ever be. Have you ever seen the size of drag turbo's? They're huge. The gearing in the transmission is set up for drag race, as is the motor. The boost comes in at high rpm because they have time for it to. On a street setup, you'd want power at the lower rpm's, which a properly spec'd single turbo could very well do. These days a twin turbo setup is more wood factor than anything else. That, and two smaller turbos are easier to come by, and sometimes cheaper than one large one.
-Thomas
*sigh*
(digs out his turbo knowledge)
A number of you are on the money on some things. A number of you are not.
A single biggie turbocharger will have lots of topflow but lots of lag. Drag cars don't care so much about that, because they already spin off the line, so the lag is helpful. By the time they get traction, they are also getting boost. Now, the lag would be so bad that it would take longer than that, except for the fact that bigie turbos are often paired with biggie exhaust.
See, something that is very different with turbocharging from natural aspiration is that a naturally aspirated engine needs some backpressure in the exhaust piping. A turbocar does not. In fact, you want it as wide open as possible. Why? Well, the exhaust manifold sees the turbine housing as a major restriction, and creates more backpressure than you will ever need.... so having a wide open exhaust after it is ideal.
Using nitrous to spool a turbo is for the really crazy tube chassis drag setup or for the inexperienced. Running the proper exhaust pipe size is how you *should* be doing it.
Now, in the case of twins versus single, you have to be more specific about what turbos are being used in a twins setup. Sure, if you run twin T25's, a huge T66 will outflow them still. Of course the twin T25's will outspool it.
But what if you are running twin T3 turbos? This changes things dramatically, and now you have to consider that, while a T3 cannot flow as much as a T66, two T3's can.
Here is why: Consider a car with a T3 single vs. twin T2's. The T2 is only good for about 14 psi, after that it's overspun (meaning it has to spin so fast that it generates enough heat to cancel out the comression with heat expansion, meaning it makes no more boost). The T3, on the other hand, is good for about 18 psi properly tuned.
Bare minimum on most external wastegates is 7psi (that's what the spring is tensioned to). SO... imagine TWIN T2's. Running the minimum boost, they are each pushing 7psi, in parallel, into the same piping, for 14psi. At 7 psi they arent making much heat, so are well within their efficiency range. Yet have superior spool to the T3, and less crazy exhaust pipe requirements. As you push them to 10 psi, you are now still within their safe zone, but now pushing *20* total. Now you outflow the T3, still in efficiency range of the T2 flow maps, and still with superior spool. See?
Of course, it's not actually 7psi + 7psi = 14. You lose a pound or two. But still the strategy works better.
NOW, finally, there's the issue of compression. Look guys, these V8's aren't low compression like built turbo V8's, or even like factory four and six cyllinder turbocars. Typically those cars run anywhere from 7.5:1 to 8.5:1 and no higher. Some carefully prepped engines run 9:1 but they don't run alot of boost, only about 7-10psi, and generally are more torquey than big HP numbers. Big HP cars run lower compression, high boost, big exhaust. I don't see many of you ordering 8:1 pistons any time soon for a turbo project, I see many of you interested in bolting something on. IN that case, expect to run 7psi, not the biggie 20 psi of the OEM turbocars. Trust me, 7psi is alot! You have to consider that before you reach positive pressure, you first have to defeat the vacuum an engine generates. So 7psi is alot! 7psi on something like even a '94 Romeo will probably make it haul like no tomorrow. If anything it might even be the better choice of engines for it, since the smaller ports would act as velocity stacks durring turbo spool time.
If I had the time I would do it. Twins are easier on a V8 than running a crossover pipe for a single. Actually for the same reason, twins are probably going to be cheaper. Twin T2's. I can pick up a T2 for 50 bux a piece in perfect condition. They are small so they should find easy room under the side of the head. Together they have the potential, without intercoolers, of safely putting out 14psi (7 each), and WITH an intercooler (or twins, come cheapo DSM sidemounts, one for each), can put out 12-14psi each for a total of well more than I will ever need.
I think you'd see this undesirable '94 engine wake up and run good numbers.
Say, anyone have any pictures of a '94 exhaust manifold? :xpwink:
Discussion Starter #15
Arro said:
*sigh*
Is it possible the inherent efficiency of one single turbo out weigh the reduced lag of two singles?
Does compounding, a larger turbo and smaller turbo in a series, provide realistic and bigger HP potential? And would it be streetable or would it only work for a drag car?
Arro said:
I can pick up a T2 for 50 bux a piece in perfect condition. They are small so they should find easy room under the side of the head. Together they have the potential, without intercoolers, of safely putting out 14psi (7 each), and WITH an intercooler (or twins, come cheapo DSM sidemounts, one for each), QUOTE]
look under your hood again and tell me you can fit a turbo on each side and you are going to stir something up here to drive people insane
the 4.6s footprint is as wide as a Ford 460
it barely fits... slap headers on, and there is even less room... now way you are going to fit extra plumbing right there for a turbo
on the driver side there is this nifty thing called a steering column that further reduces clearance
Please please please look carefully before posting stuff like that dude.. i don't care how small a t2 may be... thats why SirWill is trying his setup with a front mount near the bumper
yeah on a mustang there is a lot more room on either sides of the heads for turbos, or in the fender wells because those are roomy too. For the mn12...aint gonna happen. Way too tight of an area in there. The mid-length headers for the 4.6 nearly touch the side wall. Down by the cats there is more room than beside the heads, but probably still not enough to fit turbos there, its still a very tight spot. On the v6 and 5.0 there's room down by the cats for turbos, and I bet you could do something with that, but the 4.6 practically fills the entire engine bay of the mn12.
-Thomas
JamesD, you're close but mine is in the rear....near the bumper. :D
I'm looking at it more closely and thinking of more southward.... low. No extra plumbing, just using the present collection points, and intercepting it. As much as you may feel I am underestimating the space problem, I am not entirely certain it can't be done.
This engine was rebuilt in my buddy's shop, and put back into the Bird. I've had some quick glances at it, I admit nothing serious but nothing from memory seems out of possibility. I might have to have them low slung, but so what? Again they are T2's and mayb you don't realize how small they really are...??
I'm not spouting off I promise, I just think it may very well be possible the way I envision it.
I won't be able to lift it and snap pics any time soon but my biggest concern is the orientation of the turbos. But anything is doable with enough ingenuity.
quick question, whats your vw sportcoupe? Is it a g60 corrado? My roommate has one.
Anyways, if you're going to go twin turbo with t2's it might not be too bad for power actually, seeing as how twin t2's pushed a stock motor split-port 3.8 mustang into the 11's. But on a heavier car and larger displacement they might not be as efficient. Should be interesting to say the last. I think it might be easier to mount them in the fender wells. t2's are small enough to fit there on an mn12. Plus less pipe routing for the intake tubing. if you put a turbo back behind the motor you'll need your exhaust in/out and intake in/out pipes all running back there, which could be very cluttered. But hey, if you think its doable go for it. I'd like to see it done.
-Thomas
1 - 20 of 44 Posts
