1 - 20 of 58 Posts
i just went to go to lunch and i noticed that there was a puddle under my car. i back the car up and see it is antifreeze. so i open the hood and look around and i see antifreeze sitting in one of the nooks in the timing cover. at first i thought it was the heater hose leaking and dripping down. so i started the car and i go look. no water coming from the heater hose, but is slowly trickling down and it looks like it's coming from behind the cover. any ideas or anyone know wtf is wrong this time......???
could be the legendary head gaskets.....
i f-n hope not. i just put this engine in because of that. i dont think it is tho, doesn't run like it, and no milkshake oil/white smoke. still runs strong, so what gives? maybe timing cover gasket?
Coolant doesn't run in the timing cover at all. Closest thing to it are heads, and possibly a heater hose. That close to the front of the engine, possibly the water pump, or a radiator hose.
def. not hoses could be the pump, because i had a clutch fan on there when my elec. fan went out. was just a touch out of balance and now the shaft is slightly warped. culprit?? i hope so because water pump= a lot easier then hg's.
i would suspect a water pump, or the cover itself being warped from teh shaft bent...
approx. how much is a timing cover and how hard is that job? i think i'll just replace the cover AND the pump and call it a day.
well, coolant passes through the holes in the timing cover. how else is it going to get to the water pump?
sounds like the cover isnt sealed all the way, maybe an area where not enough rtv was applied? either that or the cover has cracked. just my .02.
i have a timing cover that's painted bright silver. ill sell it to you cheap.
honestly, i don't care what color it is. my eng. bay isn't show quality so it doesn't matter to me. how much work is involved with removing it? obviously the w/p has to go, but after that? thanks for the help.
btw, is it ok to run it like this, as long as i keep the coolant up?(until i fix it)
getting to it is the tough part. part of the wp/timing cover shares studs with a black bracket that bolts to the ps/alternator bracket. the ps/alternator/bracket can be unbolted in one big piece. make note of where each fastener goes. grab a haynes manual to help you out.
i wouldnt keep driving the car. the cooling system is pressurized and can create bigger leaks. find a buddy that knows what he is doing to help you out.
i'm mechanically inclined enough (15T, U.S. Army), but i've never gone past the w/p on this car (taken off p/s pump MANY times) well, other than pulling the entire engine. i just wanted to see if it was overly complicated as to set aside the proper amount of time. i'll probably just go to a j/y and get one. i'm not trying to be pretty. you think the '97 timing cover is the same as the ones prior?
it just your timming cover gasket mine did that after I did my heads turns out the cover might be warped so I just used a s-load or rtv on it hasn't leaked since
Discussion Starter #14
better to do that while it's on the car? i think i'm gonna change it, i don't like rigged up shi* on my car. no offense :)
most water pumps have a weep hole that will start to seep coolant once the pump seals start to fail
I changed the gasket and it still leaked thats why I did it this way
the weep hole is on top of the shaft for the water pump.. that wouldnt be water INSIDE the timing cover...
he never said inside of the timing cover
Discussion Starter #19
yeah not inside, behind, or at least it looks like it's behind it. not the pump, as that would be leaking from under the pump. it's def farther back
I'm with Mike on this one. My 97 was recalled to have the timing cover resealed.
1 - 20 of 58 Posts
