1 - 2 of 2 Posts
9 inch ultralight
Product Information
9 inch race converter for ultralight operation fits 31 spline converted AOD transmissions. Also available for c4 and c6 applications.
Available in stall speeds 3200 and above depending on application.
Includes all of the following features
3 bearing design to reduce drag and increase durability.
Furnace brazed pump with 1/2 balloon plate and hardened impeller hub.
Furnace brazed turbine with tig reinforced fins and hardened splines
Optional stator choices to meet your needs can be used in street strip or full race setup, price will vary.
Cost is set for billet aluminum stator with 22 element sprag assembly. $100 discount for spragless with aluminum stator, steel stator with spragless is the same price. $100 price increase for steel stator with 22 element sprag assembly. Not sure what you need? Call us and ask for Alan.
Billet steel front cover with bushing to center turbine.
Ultralight converter weighs less than 28 lbs in all applications. Some as light as 23lbs.
Computer balanced
Includes hardware
Call or email us to discuss your needs today
(513) 898-1580 Alan at dirtydogperformance.com
As always tccoa members get a 10% discount.
Check out out latest cooler addtions as well. We have the parts that put you ahead of the pack.
Chapter Director Coordinator
mod bump
1 - 2 of 2 Posts
