So looking for some advice as I've been fighting a miss with my 94 4.6 bird. No check engine light so I've replaced the plugs, wires and coils.
Usually those misses related to spark occur at a lower RPM, like 1500, when climbing a hill in OD. High load and low RPM. Hopefully you replaced the coils with Motorcraft?
2500 is above normal cruising RPM, you're really starting to get into the throttle then, unless you have gears.
Al
