as always, i trust you guys first b4 buying. so i want to know what to get and from where? also, will i be able to use em once i do the engine swap to 02 exploder?
I run the Steeda UD's on my stock 95. No piggy-back pullies for me. You will have to double check that the water pump pulley will work for the 02 explorer swap though. I believe the one's I have only work for the 96-01 motors.
The only other thing I can think of is make sure you put some sealer around the keyway when you install, or you could end up with an oil leak.
Jay
Funny you should ask. We were just discussing pullies over HERE. In case you didn't see it check this thread out.
BTW, I'm also running the STEEDA Pullies on my car.
sold
