I have a 94 4.6 LX, and I have noticed that the drivers side front tire is showing signs of wear on the outside edge.
I know that if the tracking is out of adjustment the tires will wear on the edges, however the passenger side tire appears to be fine and as far as I know all the joints and bearings are ok. I'm going to get the tracking checked anyway to be sure its ok.
The car drives fine and doesn't pull or wander. The pressures are set at about 32psi.
I was wondering if it could be because we have lots of roundabouts over here and that would be the tire that's on the outside everytime (turning to the right)?
Can anyone tell me if they have experienced similar wear?
Sounds like your camber is way off (positive) on that left front tire. What did you find when you got the car aligned?
