1 - 19 of 19 Posts
Confirmed V6 Nut
I see that upgrading a 97 block to be a splitport motor isn't as simple as plopping splitport heads and Mustang upper and lower intakes on it.
Other thatn a funky EGR setup, a different fuel rail, and a different TB, IAC, and TB linkage, what are the gotchas? Can I just use my DIS and single port coil?
You can slap the splitport heads and intake on the 97 block.. you'll just need the modified fuel rails etc. You can by the topend kit from rpm-mustangs.com
Confirmed V6 Nut
NiteFire,
I've seen the kits offereed by RPM and by Super6. I have not seen much on a head and intake swap.
I have the splitport heads from a 97 F-150 and the intakes from a 2000 Mustang. I now know I'll need a TB and a different IAC. I believe the Mustang TB forces me to use a different throttle cable.
The EGR is different. I go back and forth between deleting the EGR by using a chip and a plug to putting in some parts from the "parts bin".
I'd just like some info on the pros and cons of what needs to be changed because of the differences in parts.
I may remote turbo this car down the line. With the 2000 intakes, I won't have problems on that score.
so... does that mean the ngine in my 95 lx is identical to that of a 95 mustang 3.8? and if so, is this a direct bolt-on for me? that would be great!
Confirmed V6 Nut
I think the intakes and Throttle Body are still different, but I've been known to be wrong before.
The heads, block, and most of the accessories should be the same or at least bolt in.
i would hope so.. this sounds liek a good project for spring... if anyone can source up some info, or a guide, it would be much appreciated. and the intake and tb are going to get replaced.. it will preobably have to be tuned or chipped too, right?
Confirmed V6 Nut
I think we are asking for the same type of information. What is really different about the different year engines and configurations. Some articles I'd like to see:
How to switch back and forth between splitport and single port.
How to go back and forth between EFI and non-EFI.
How to go back and forth from electronic ignition to distributor
Now am I asking too much?
the 95 mustang is the same engine. the SAME engine. no difference in performance or power at all. a swap would be of no benefit to you at all, whatsoever.
Dan,
Delete the EGR, you mentioned not chipping it if you kept the same injectors, MAF, etc. You're still flowing more air and need more fuel for that, that the stock tune computer cannot compensate for you. You need a tune, or at the least, a chip. If you're doing this, you might as well use 19# or 24# injectors so the extra power is getting extra fuel without any doubt in your mind. Also, if you need the chip anyway, spend less money on the swap and just delete the EGR. It will save you headaches and time and money. All beneficial to your project eh?
Your throttle cables will work, and being a 97, you have the 4r70w. The bracket should work with your cables, but you might want to consult racecougar, SplitPortBird, or 4.3cougar to be sure. They have the experience, I just have the book smarts.
-Thomas
I don't remember exactly what the problem was with the throttle body linkage, but I do remember that we had to cut the linkage off the 2000 throttle body, and weld the 94's linkage in place for the cables to attach to it correctly.
As long as you don't have to have the EGR for emissions, I agree with Thomas, ditch it. I'm running EGR simply because I would fail the visual portion of the emissions testing without it. You're definitely going to want to get a tune anyway.
-Rod
Research before reply. the kit i was questioning about is to upgrade the 95 singleport stang. so it should just bolt up to mine. is the 97 identical?
Resident Line Creator
I'll throw some mixture into this thread. Is it much more work to get this to work on a earlier 3.8? Oh say, an 89?
Yea, it'd he alittle harder. You don't need but its reccomended you put a shiftkit in your AOD or have it built with 4r70W Internals. You'd also have to hook up your distributer or convert to DIS. Other then that it should be like a swap in a 94+, though the 94/95 should convert to DIS also.
Confirmed V6 Nut
Discussion Starter #15
You'd think a simple intake and head swap on a N/A V6 would be just that!
Well, Thomas now you see why I was asking about the Mustang TB. I see RPM-Mustangs has a "stripped" upgrage kit for $400. I might be able to swing that and the TB if I have what I think I have left over from painting my car. I don't know if I can go a Chip set up. I think I can get a programmable from SCT, but not sure I can swing that right now.
I mainly stay below 2000 RPM in my driving, except for the Clashes and possibly Hangoverfest. Thought I could get by until spring without the chip or the cam I have waiting to go in.
Oh anyone know which ARP head stud set works with the splitport heads?
you never mentioned anything about split-port swaps, just the 95 engine and yours. Maybe you could word your sentences a little better ;)
a distributor will fit with the mustang intakes if you delete the EGR or make a custom EGR pipe for it. You do NOT HAVE to convert to DIS.
-Thomas
i was asking for the similarities, simply because i wanted to try this splitport upgrade... that should produce some benefit. the splitport upgrade is designed to upgrade the singleport stang engine, to a splitport. if they are IDENTICAL, tehn that means this should be a moderately easy task. my engine seems to be due for a rebuild, so the upgrade kit is DEFINATELY going on my christmas list. heh.
well then yes, if a split-port swap works on a mustang 3.8, it will work on your 3.8. The kit supersix sells for a 95 mustang will also work on yours. If you have emissions inspection, or visual inspection, you will have to either convert to DIS or make a custom EGR tube.
-Thomas
...... as soon as i replace that damn headgasket..... *grumble*grumble* time for a more open exhaust....
1 - 19 of 19 Posts
