Hello, this is my first post, so if i have confusing info, im sorry. Anyways, I have a 1997 t-bird was approx 150,000 km on it with a 4.6 V8. Coming home from Brandon, my low coolent light came on, and my temp started to rise. I pulled over at the next mile road, and stoped the car and had a look under the hood. There was Anti-freezer all over the place. I was not sure where it was leaking out of, i filled my reservor up with water, and started the car. That is where i seen the leak. It was coming out behind the Alternator. So, i left the car there, and got a ride home from the brother in law, and got the truck and trailer, and picked up the car a few hrs later. Today, i took the car off the trailer, placed it in the shop, and took the Alternator off to have a close look at were the anti-freezer was coming out of. There was 2 cracks on the Upper intake manifold, right behind the Alternator and beside both sending units. On pervious years of thunderbirds this was a 2 peice unit. The anti-freezer went throw a cast peice, and the rest is plastic. But for unknown stupied reasons, ford went with a 1 peice, all plasic upper intake. Thus, i guess that is why it cracked on me. Now, my question is why will that have cracked like that, and will a 2 peice upper intake manifold work off a 1996 t-bird with a 4.6 V8 work? Thanks :D
All 96 and 97 thunderbirds cougars and many other 4.6's came from the factory stock with a 1 piece plastic intake manifold there was a huge recall done to have the manifold replaced with the newer 2 piece manifold you are refering to. If you have access to a 96 with the 2 piece manifold with the aluminum cross over that you can use then yes that would be a direct swap for your 97.
As for why it cracked. It was bound to happen sooner or later. Those solid plastic manifolds are ticking time bombs.
The all plastic intake went 96 through the 2001 model year on some cars. I let the one on my 2000 Grand Marquis go as long as I could, it actually didn't fail by cracking, but between a flattened gasket and what looked like leaking rear coolant nipple, I finally swapped it out at 143,000 miles. I should have done it some time ago but didn't.
