On the 96/7 upper intake plenum, what is the rear (towards the people compartment) fitting for and where does it go? I have quite a few pics, but I can never tell where it goes to and my manual doesn't say anything about it. Also, this may be it, but where does the evaporative emissions line come from on the passenger side?? Thanks
Chapter Director Coordinator
i know if you follow it, it goes over valve cover, down pass side and is bolted to pass shock tower, and then goes under engine somewhere...
want an accufab upper? :D
So, on my 94, I have 2 lines that come into the PCV valve on the passenger side valve cover, and one goes out to the canister or somewhere (not really relevant right now). So in order to make this work, I will just need the piece that goes from the rear to that line that goes to the canister right? I think the other one ran to the intake manifold somehow, but it's really hard to see back there. The PI intake doesn't have these ports right??
