:wavey:
does anyone know how much movement at the upper shock mount, if any?:zbash:
making an upper mount plate. Need to know if I need a shoulder bearing.:zdunno:
:headbang:
It needs to move; the Shock Shaft angle varies inboard to outboard as the suspension moves up and down around the pivot of the inner lca bolt, and it moves front to back with the strut rod bushings flexing on both ends. (hopefully, not as far, lol)
If you're going to make it solid, it needs a spherical bushing or bearing that supports movement; Or it may break the shock or shock seals.
That said, This part is the big thing keeping me from buying Race Konis; the shaft is bigger than stock. :)
Not sure how much, but it'll pivot around the shaft some (not circular, angular) as the LCA goes up and down.
Am I on everyone's ignore list?? :D
Grog - I bet you were typing yours as I was typing mine. And with mine up there, Matt MAY not have seen yours.
