one big thing the 2011 has is direct injection.from a sheer power output perspective, it absolutely makes my point a valid one....exactly what progression of technology? just because it has variable cam timing? if you lock the timing of the camshafts to the upper RPM range (for sheer high-RPM power output), then there isnt much more to the newer engine---it has tremendous volumetric efficiency (> 100%)....that can't be done with a dedicated intake/exhaust manifold and custom camshafts on an older modular engine?? sure it can!......just takes time, money, and knowledge....the 2011 runs nearly 11:1 compression....that can't be done on an older mod motor? sure it can!...the 2011 runs oil squirters aimed at the bottom of the pistons for cooling......yes that helps, but the Cobra R didnt have them, it it made tons of power without them, and there are other things like coated piston tops and alcohol injection kits that can curb intake charge temperature upon the compression cycle.....the 2011 motor has a bigger bore, helping unshroud the intake valves....cant be done on a mod motor?....sure it can!...its called a big-bore "4.6", aka 5.0L mod motor
my point being that the overall design of an engine takes precidence....a well planned out (and dedicated) big-bore "4.6" 4V can make more power than the mighty Cobra R DOHC 5.4, without the hassles of installing the taller-decked 5.4 into the cramped up MN12 engine bay
