1 - 20 of 22 Posts
02 Explorer Pioneer
Yeah a stock 3.8 will never take the abuse. The supercoupe 3.8 was a whole different animal.
haha yea so i wont mess around with that seeing i just got the car, ill stick with pulling the silencer, getting some cold air system and underdrive pulleys to start
The cheapest V8 swap is a trade in on a t-bird that came with one. :D
i have been thinking about putting a supercharger on my 97 bird. i got it from a friend who put in a 00 explorer engine with pi heads. about how much boost can i run before i have to change any of the engine and about how much can i stand to gain from that.
02 Explorer Pioneer
I've been running 6 psi on my explorer motor for 80,000 miles now. Sensible driving and a sensible tune are the key
do you have a t bird or exploder computer running your car? and to do this, what kind of tune, or tuneing computer should i get, or have done. also, if i may ask, what parts are you useing on yours and how much have you gained from it
02 Explorer Pioneer
94 bird computer tuned by SCT. I am running the SVO blower with the install kit as it comes in the FRPP catalog and I added a Mustang MAF and Lightning ACT sensor. I haven't had it on a dyno so I couldn't tell you definitively how much I gained. With good traction I am certain the car is good for 13's in the quarter but there are others here running the same blower with a higher stall converter that are in the 12's.
MaleWhore
i dont want to start a new thread but what options of SCs can be thrown in our cars....so far i know AED works, SVO and vortech. can the paxtons or etc work in our cars?
Low Boost Is The Only Way
Keep You Boost At 6lbs Max ..you Should Last A Long Time:d
AED Specialist
Thunderroad,
No boost is safe with hypereutectic pistons, if you think a great tune will keep a stock 4.6L engine alive forever, you are wrong.
I've seen two NATURALLY ASPIRATED 4.6L engines with busted/cracked ring lands on the pistons. No nitrous, no blower, no turbo. Things can go wrong even with a great tune.
Are you safer with less boost? Generally speaking yes.
A-Train
MaleWhore
so basic question....are used superchargers relaible?
Sure. I mean, depending on the condition and mileage, it may be in need of a rebuild (which can run you anywhere from $200-$1,000 depending on the unit) but generally buying a used blower is fine. Just make sure you get everything that came with it. I don't know how many used kits I've seen for sale that have been missing brackets here, or parts there.
My used vortech is running just fine 20,000 miles later...... And the 96+ N/A 3.8L's handle 11psi boost pretty good and should last for decent amount of time. Mine has 110,000 on the shortblock, the last 20,000 with 9psi boost and beating the living heck outy of it! :D
MaleWhore
what should i look for in a used kit part wise....
1 - 20 of 22 Posts
