my maf in my 96 died, i got one from a 94.. do i need the harness to use? if so do i take all the wires or just snip?
This is an odd question. I never switched backwards before.
When you switch from a 94/ 95 to a 96/ 97 EEC you need to replace the wiring pigtail. Therefore, I believe that simply switching the wiring can do the job.
However, there may be a slight problem if the MAF curves between the years are different. If they are different you can get drive-ability issues. I do not know the answer to this question.
The safe bet will be to go to a junkyard and get just the sensor from another 94 or 95 Bird or Cat.
Refrigerator Raider Hater
