hi
i would like to have my 95 v8 tbird have rike but i would not like to cut stock ones.
so would v6 spings do that & I did do a search but got nothing, has anyone done this before?
thanks
What are you asking? what is rike? Do you mean "rake" look? What makes you think V6 springs would give it that look?
Why not just buy a set of lowering springs and change only the fronts?
You will probably get a little bit of lowering out of the front but thats wear the benefits end.
Most likely end up with early wear on your shocks//struts and your handling will suffer a bit might feel like your pushing through corners.
I say save the time it would take to take V6 spring off and put them on and just save money for lowering springs.
thank for the replys.
guys
