on the plenum leading into the intake manifold there is a 2 way brass fitting it has only one line leading to it. i cant find the other line and the diagram i got from the dealer shows it but not anything leading to it. I am only running about 7-8 pounds of boost because of it. any ideas
One of the lines at that fitting goes to the vacuum distribution "tree" on the wheel well in the corner by the brake master cylendar, I think if that line was missing the car would really run like sh!t.
The second line goes to the back of the inlet plenum for the SC in called a crosstalk tube and is about 6-8 inches long. This is likely the one that is disconnected since some people have tried to eliminate the tube altogether with no performance increases.
hey thanks for the advice traced it down and it was unhooked. car runs a ton better and actually have a decent brake pedal :D
also was missing tube from intake tube to pcv valve the boost is back to where it should be now 10psi
If you put a hose clamp on every vacumm line you can get to.And a plastic
tie on the smaller vac lines with nipples you will notice another gain in performance.
Try to put a clamp or tie on all the vac lines on the boost side of the vac line.
pcv valve lines ,ect.
randy
