You would need to get the 6-rib pulley, belt, and the intake and discharge piping. And as far as your fuel system you can go many different routes. I have my front mount intercooler with piping from my bird for sale btw.
well i have the kenne bell boost a pump that i used on my 5.0L do you think that would work
but as far as the brackets they are the same?
as far as the boost a pump i cant comment on that because i have never seen one nor used one. It may or may not work, you would have to do the research on it. I was using a 255 lph in-tank pump with 42lb injectors and i never had a problem. To me thats the right was to go instead of sending more current to an already overworked pump with the kenne bell. (personal opinion) And as far as the bracket it will bolt right on to your bird no problem, the engine is the same as the mustang's.
Clueless Poster
trade an m90 :)
cant do that sorry
