Everyone likes to save money right!
Polyurethane Springs Isolators desinged for a 99-04 cobra (just the lowers) are the same as the Tbirds. Prothane recently just started selling the lowers seperate and Laurel Mountain Mustangs has the for $15.95 a pair! thats $31.90 for a full set! Much better then $60 advertised other places.
Laurel Mountain also carriers the Diff Bushings for $37.95! and this is the Polyurethane Stackable type (Using Washers) so pinion angle can be adjusted if need be.
Lastly, I'm ordering a set of 03/04 Cobra Rear control Arm bushings for $63.95 from the looks of it it will be a Polyurethane replacement for the Thunderbird/MarkVIII control arms. As of now nobody makes a polyurethane replacement for these so I'm gonna order them and trial fit em.
Here's the LINK:
http://www.laurelmountainmustang.com/index-1024.htm
Hope this helps someone out!
Brad
i picked up my Steeda poly IRS bushings from Jeff at nitrostangracing.com for 33$
Brad
Did you trial fit these yet?
Will they work?
SanDiegoLXBird said:
I realize.. but their spindle bushings are cheaper than MN12 performance.
I agree,, I was just stating that they only sold that item for us. and yes it is cheaper then MN12Performance. I should of included that line.
Will they work?
Yes I have trial fit and they fit great.
Havent got car on the road yet though.. engine install taking longer then expected.
A quick clarification...
The bushings that Rich offers at MN12 are rear spindle (knuckle) bushings. The Prothane Cobra kit from Laurel Mustang (#6-311BL) is for the upper/lower control arms to frame... different bushings.
That is all...
