1 - 11 of 11 Posts
What happened?!?!
Water totally drains out of the radiator and ends up coming out the tailpipe...
Head gasket? Intake manifold?!?!
Help!!
3.8L
Let me know what you guys think...TIA
Dave
Whining Intakes Rock
Head gasket would be my first thought.
yea or cracked head
Or both. Most likely head gasket though. Either way the heads have to come off and get checked out by a machine shop.
Mike
With the 3.8 head gaskets are the obvious fist choice answer but until you pull the heads you won't know if it only needs a head job or what...
yes head gaskets.....i had the same problem, coolant pouring out of dr. side pipe (true duals)........ but both sides head gaskets were toast........get your heads resurfaced, don't just replace gaskets, and also replace the head bolts.
Yea hears a new memeber of the head gasket club
my guess would be it was so bad it cracked the head(s). most of the time the water burns off giving the white smoke effect, not spewing out the tailpipe.
i had all the above (shooting coolant and white smoke) no cracks in heads but i put the brand new heads on (less than 5,000 from the previous motor, motor had lower end problems and the owners before replaced the whole upper half). got lucky on that
ECU_Q said:
I wonder how many of us there really are.
I wonder how many aren't? :(
1 - 11 of 11 Posts
