hey guys,.....seems as though i have a leak at the water pump (pump is fine),...so w/ 150K on the ticker, i'll just replace the pump and gasket......Here's the question......my engine bay doesn't have a cap on the radiator to fill 'er up. Does anyone have any suggestions on how to replace the fluid i'll be draining? thanx
<img src="http://members.tccoa.com/94birdnj/bay.jpg">
Trumpeter Extraordinaire
The coolant recovery reservoir is located next to the battery. It's marked with a "full-cold" and "full-hot" marking. The cap on it should be removed when the engine's cooled; you can add coolant to the reservoir.
This article may provide additional info on what to do as it addresses refilling and bleeding the cooling system.
yeah,....i knew where the resevoir was, but wasn't sure if there was some sort of way to fill the radiator that i hadn't known about. At a meet, me and Danman put our cars side by side, and we couldn't find out why his car had a radiator cap and mine doesn't.....thanks for the link though!
