Fry Rice Specialist
it has a plate at the impeller thus improving flow. i have one in my bedroom.
There was an improvement to the water pumps in 02. From what I understand they are the same as the 00 Cobra R pump.
The online Ford Dealer shows the same water pump for GT and Cobra from 99-04. I'll run down to the local dealer and check it out. Doing the PI intake swap soon with 145,000 mi. Might as well look into a new pump too. Hate to put it all back together only to see green stuff on the ground the next day.
lonnie, can you put a gt pump on a 4.6 truck motor?
The truck motor has a fan on the water pump assembly, and I would replace that with a e-fan setup.
JH
Chapter Director Coordinator
i replaced mine w/ a bullit water pump that features that nifty impeller ring
make sure you get the right style cuz of the snout lengths.. might need a new pulley
The 02 GT pumps feature that same ring style impeller. The earlier pumps have an open impeller.
As for fitting on a truck JH, I'm not sure. I've never compared the two. I'm sure it will fit on the block but whether the flange is in the same location so that a pulley would line up I couldn't say. Your best bet would be to have the auto store open them for you so you could compare.
High-Mileage 4.6L Thrasher
JH
I have one on my truck.Replaced it when I did the e-fan.
JL
