I have just purchased a mercury cougar 4.6 and on the way home the glove box started making a beeping noise from the glove box area and finally it stopped before I could get home. Does anyone have any suggestions about the noise?
thanks
cr
45 Primary Crash Sensor #2 - Not Mounted to Vehicle Properly
Check the connection. I had a similar issue the sensor connection was just loose. Hope it's something as simple as that. The airbag module that sits behind the glovebox (right side) is light blue in color and can be expensive to replace. Try to find one in a bone yard if you have to replace it.
