when i put my car in neutral it revs up to about 1200rpm then comes down to 1000rpm but when it is in drive it stays at about 750 rpm. so i was wondering i had bought some throttle body and air intake cleaner so is it bad to get that stuff inside the throttle body or no?
Refrigerator Raider Hater
Maybe abit high, but sounds normal to me. Your engine idles lower in drive because of load. When you take it out of gear, the sudden relief of the load causes the engine to rev up.
thanks and by the way u were right about the last problem i had it was the engine the spark plugs were not gapped right.
