MaleWhore
this i started noticing yesterday: as i accelerate over 20 mph, the car starts making this humming noise under the hood( well i think its under the hood, as i can clearly hear it if i get closer to the wheel as im driving). its just constant little humming noise, that doesnt sound really bad, but its like close to a sound of a differential noise on some cars...i just dont know how to explain it. i was playing around today and this noise stops for an instant if i move the wheel, but just for like a split second...it doesnt sound like its the power steering pump or anything, and right now i dont know what it is...just wondering what u guys would think and if this has happened to anyone...thanks and any input is appreciated...
It could be a wheel bearing wearing out. It happened on mine recently, and the noise sounded a little like a tire hum. It increased with speed. One good indicator that it is a bearing noise is if it goes away when you turn one direction. I.E., if you turn left and the noise goes away, it's likely the left wheel bearing.
I also had a tie rod problem, which exacerbated the bearing problem, but the bearing noise was still quite noticeable after that got fixed.
MaleWhore
are the parts expensive?...could it be done on my drive way?...cant afford to go to a shop and do this....i bet it would be expensive at the shops...
If it is a front wheel bearing, you can do it yourself, as long as you have a 36mm wrench, and a torque wrench capable of applying 250 lb./ft. of torque.
If it was a rear wheel bearing, it gets a little more involved in replacing it;
http://www.sccoa.com/articles/rearwheelbearing.html
MaleWhore
does anyone have the steps for a front wheel bearing...how about the prices? i am pretty sure its the fronts....
The front bearing comes with a new hub. You remove the brake caliper assembly and rotor, then remove the 36mm spindle nut, and swap the hubs.
