1 - 20 of 39 Posts
My 3.8 Essex in my Thunderbird is making a whooping/mooing sound coming from the upper intake manifold when shutting off, and you can feel each combustion chamber hit one last time. Any ideas on what this could be? :confused:
Have you checked for vacuum leaks?
I've checked and found none leaking, but its hard to hear for a leak seeing as my ps pump is going out so it whines, but i checked and couldn't find one.
Try spraying soapy water, or use an unlit propane torch around the vacuum lines and manifold. You can see the leak (if there are any) with the soap and water, or when you hit one with the propane you will hear it when the engine sucks it in. Also check around the throttle body.
I just recently took the MAF off and cleaned it(last week cause I thought that was the problem.) And the airfilter is still clean but its a fram so im looking into a k&n airfilter. And tommorrow i'll try the soapy water thing.
the k&n is not going to help you... the only advantage you will have is being a reusable filter. our engines do not suck in enough air.
I've had plenty of experience with cars that don't suck in air, such as a ford taurus. and trust me a k&n is much more worth it than this fram paper filter.
im not saying your wrong but i prefer the k&n compared to whats in there. compared to what feels like 5 layers of contruction paper stuck in my intake i'll take just about anything else
so i figured out my engine light isn't lighting up cause this has to be throwing codes, im trying to get the dash off but the light nob refuses to come off, is there any tricks to get that little lever release to let go.
Discussion Starter #14
I got it I just had to pull harder. And there was no bulb in the socket. So I put one in, so now if it doesn't light up the computer doesn't know anything right? or do I have to do something to kick the computer into gear?
That sound that you're hearing from the upper intake when turning off is a common precursor to the failure of the IAC (idle air control). If your car suddenly starts experiencing a high idle, you'll know that the IAC's done.
-Rod
Discussion Starter #16
well thats good to know because i idle at over 2000rpms, will that throw a code?
and is there another name, i can't find it on the autozone site
-Rod
:zwthstpd: i would start there as well .
The IAC may not throw a code. Mine never did when it died. I also had the same problem with getting a new one, the guy at the store knew what I wanted but couldnt find it on the system. Youll prob have to go to a dealer, or get a used one from a wrecker.
dont botherwith a used one, not worth the time and effort
1 - 20 of 39 Posts
