1 - 10 of 10 Posts
Ok guys having a weird issue here.. On acceleration or bump the trottle in neutral i can hear a rattling type sound. It doesnt get louder with rpms, if i unplug the #3 injector on the drivers side and rev, the rattling/tapping stops, and sounds like it should.. I pulled the plugs they look good, swapped injectors around and it still does it on that one cylinder... It almost spounds like a spun bearing but i dont think thats the issue, or hope it isnt anyhow. Whats ur thoughts?
Edit: just unplugged the coil pack for that cylinder, rev, no noise.. So no fire in that cylinder = no noise.. Perfect sound motor :(
Plug it back up, rev, rattle sound came back
That means something in the bottom end is bad. It could be a rod bearing worn out, or maybe a bad wrist pin. Either way, time to pull the motor apart.
Can you take a audio/video for us? Does sound like something like Mikey said although I've never heard a bad wrist pin. I've heard bad rod bearings and broken skirt causing piston slap several times though!
yeah, sounds like something is loose in the rod on that cyl. without it dumping fuel its not firing and without the downward force it isn't knocking.
Yeah ill do a video in a bit
I cant pick up the sound on my phone
& mikey thats what it sounds like to me too.
so you have already exhausted all possibilities of this being a valvetrain issue? Who/when was this engine built and when did this noise show up?
Well, i was hoping for that issue other then a rod bearing lol Tappets went bad for the valves on that cylinder perhaps??
A valvetrain issue would not go away when the cylinder is deactivated. That can only be a bottom end issue.
I agree with you for the most part. I was thinking a long-shot with a valve not seating properly under combustion pressure. Highly unlikely, I know, but with out compression test numbers at this point there's a 0.0001% chance it may not be bottom end related.
cobra R thunderbird, there are no tappets in a modular engine. Do a compression test if you have one available. If anything it will confirm that it is indeed a bottom end problem.
again: Who/when was this engine built and when did this noise show up? ?
Its the one i built last year.
*lash adjusters is what i meant. Not tappets
The noise showed up after i raced it one nite. I may have over revved in my 1-2 shift. Not certain because i wasnt watching my rpms.. Too busy keeping the car on the pavement lol
1 - 10 of 10 Posts
