I changed out the rear main seal and the front seals on the trans and its still leaking oil. Could that much oil be coming from the oil pan?
if the rubber gasket is bad/missing, yes.
When you replaced the front seal did you check the front pump bearing?
If it's down to the brass It's shot.
Yeah its trans fluid and its worse than ever. Wtf even with the bad bushing I think somethings wrong ie assembly or wrong seal to be leaking so much.
