ah thanks, Im sure someone will be using that around here, I doubt me though I don't make like using giggle juice kinda takes away from having an engine thr runs off gas, lol, but that's just me, I wouldn't mind some NoS but only on the track
Clueless Poster
can i possibly get you to make a dry kit diagram m curious to see how involved it is
Why did you put the middle relay in there? I've never used the MSD window switch but it looks like it is feeding negative out to the middle relay. If you took the yellow to the throttle switch then from the throttle switch to the relay on the left while feeding a positive through the fuel pressure switch then to the relay on the left you would have the same end result with one less relay total. I would also feed the power from the main switch to the purge button to keep the purge switch inactive when the system was off.
