Why is that? Can't you get a small amount of power out of better wires, especially thicker ones?seabass said:screw that...get some stock motorcraft wires unless your simply buying them for the color.
C
not really unless you upgrade the rest of the ignition. i like them cause they look better, the stock wires are fine, "C" is running stock wires and A22C plugs on his bullitt/vortech/pi bird. he aint got no problems with them either. as far as i know. so yea the stock motorcraft wires are fine.Aaron_T said:
C
103s / 1 heat range cooler17Mark71 said:What are the corresponding part numbers for the 22c and 12c for Autolites? I understand that they (the plugs) are the same as motorcraft. I already know the motorcraft numbers. Thanks.
