As in most cases, the title said it all. What are the dimentions of the LED in the rear panels?
The individual bulbs or the whole stick?
The strip has 20 LED's, and is made by Hewlett-Packard. The LED's are 5mm square
The following numbers appear on the bottom of the circuit board: 5181-4051 and PCL-10
The first 17 LED's are spaced every 25/32", then 1/2" for 1, then 9/16" for the last two
There are four resistors on the circuit board, all the same color bands: orange, orange, black, green
The reflector for the LED is made by Hewlett-Packard, and has the following numbers: QPWR-G299, E-5041-9048 2 and F2SB-13B500
The LED strip itself is 16" long, and 5/16" wide
The Reflector (LED housing) is 16 3/8" overall long. It tapers out on one end from 16", and is 1/2" wide, and 1 1/8" high
Check out the pictures in this thread.
http://forums.tccoa.com/showthread.php?t=77235&highlight=circuit
WOW!! Rolling-Thunder, thanks, that is way more info than I was looking for, but very useful. :)
